Removes one or all MLD groups.
| v6grpipaddress | Specifies the group IP address. |
| name | Specifies a VLAN name. |
N/A.
This command is used to manually remove learned MLD group entries instantly.
The following command clears all MLD groups from VLAN accounting:
clear mld group accounting
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
